Regex Help: Combining two regexes as one regex with capturing
Setting up a variable name for user to select as a dropdown:
Currently I’m filtering on up{job=“my-running-instances”} as query
this outputs as a preview of values:
  1. up{instance=“https://someurl.com:2222/data?targetname=Ryzen",job="my-running-instances”}
  2. up{instance=“https://someurl.mystuff.io”,job=“my-running-instances”}
I can do this regex: /targetname=(.)",./
and this works for the for number 1
I can also do this regex: /.instance="(..io)"/
and this works for number 2
How can I combine these regexes with an OR ? (e.g. | )
Why can’t I simply do the following: /targetname=(.)",.|.instance="(..io)"/
Maybe I’m misunderstanding the function of the /'s
Any help would be appreciated, thanks.
Also if you have any good references online to further understand regex and how they work in grafana would be helpful.
