Regex for Time series "Fill below to"
I use the series/field override to fill the space between two series. This works very well as long as the name of the series does not change. In my case, the data comes from an InfluxDB and the name is made up of the field and various tags. The field name remains the same, whereas the value of the tag can change over time.
Is there a way to still use the function “Fill below to” without losing the information of the tags in the name?
