10.0.2 - What are you trying to achieve?
Applying a reduce across multiple queries, and dropping NaN values, similar to how this is done in reduce expressions - How are you trying to achieve it?
I setup a reduce transformation to get the max, min, mean, and standard deviation. - What happened?
The reduce transformation acts as if the reduce is strict, containing NaNs etc.
is there a way to use the reduce expressions mode selection with transformations, other than making an individual expression for each query?
