Redis timeseries and candlesticks
Hi All,
I setup a redis timeseries with key like ‘XXXX.Open’, ‘XXXX.Close’, etc… When trying to use candlestick visualization, I just cannot get it work correctly.
I has tried to use right panel to match the ‘Open’, ‘Close’, ‘High’, ‘Low’ drop down menu to match each key, but the chart only take ‘XXXX.Close’ and the other filed is appeared in ‘additional fields’.
Besides, if it is feasible to add transformation ’ Rename fields by regex’ to rename (remove XXXX.) the field name to match ‘Open’, ‘High’, ‘Low’, ‘Close’ of fields of candlestick panel field ?
Thanks!
