Recommending json server for worldmap json endpoint
I have tried a few opensource json servers to serve as the json endpoint in worldmap plugin but none of them worked so far.
Can someone please recommend a good json server that has been tested to
work ?
Thanks !
-James
Any web server should work - all it has to be able to do is return a json file. What servers have you tried and what errors did you get?
