I am trying to import third party libraries to work with it in order to avoid static linking of third party modules. Is it even possible in current react implementation.
Because i do not see a index.html file in current react setup to develop plugins. Previously we had module.html . Do we have something like that in react to develop the plugin?
Basically i do not want to use npm and yarn for static linkage .
Any help or idea is highly appreciated.
Hello @kmvijayraghunath
May be this can be achieved with componentDidMount method:
componentDidMount () {
const script = document.createElement("script");
script.src = "CDN_URL.js";
script.async = true;
document.body.appendChild(script);
Regards,
V.
Thanks for the reply… yes this method attach the script to index.html, but for some reason I am not able to access the script variable in the window object …
Example: window.my_script_exported_variable.
However, this object is available in chrome dev tools when I try to fetch from window object.
Meaning plugin module.js is loading before the scripts in network tab .
Any other suggestions are highly appreciated
