yum install worked w/o issue. Updated .ini w/o issue. But:
[root@ip-172-opt]# service raintank-probe start
raintank-probe: unrecognized service
What are the next to start this executable and configure it as a service?
Thanks,
Dan
Thanks,
Dan
Hi Dan,
What version of Centos are you running?
For centos6, can you try running
initctl reload-configuration
for Centos7
systemctl daemon-reload
Anthony
Hi Awoods,
So this is Amazon Linux, which is based on CentOS.
I ran: (systemctl is not on this, so must be based on CentOS)
[ec2-user@ip-172-31-23-217 ~]$ sudo initctl reload-configuration
[ec2-user@ip-172-31-23-217 ~]$ sudo service raintank-probe start
What should I do next to get this running? Can you point me to the binary folders?
Sounds like Amazon Linux doesn’t behave as expected. Your issue looks to be the same as the problem discussed at https://serverfault.com/questions/655395/ec2-linux-any-and-all-upstart-jobs-returning-unrecognised-service
so just run
sudo initctl start raintank-probe
Doh…thanks for googling for me ![]()
