Raintank-probe run on Raspberry PI 3?
Can I expect the RainTank-Probe to install on CentOS 7 running on a Raspberry Pi 3 (ARM x64)? The processor on the unit is:
Broadcom BCM2837 SoC with a 1.2 GHz 64-bit quad-core ARM Cortex-A53 processor
Using the following steps from the GitHub page, will it install?
• add PackageCloud to repo.
curl -s https://packagecloud.io/install/repositories/raintank/raintank/script.rpm.sh | sudo bash
• Install raintank-probe package
yum install raintank-probe
Thanks,
Dan
The packages we build are only for x86_64.
You can try downloading the source and building yourself for ARM64.
