Table Panel - Create Columns, not Filter?
Hello, I have created a table with a couple of queries and I just want the results to appear in 2 columns. I have done this in the past but Im thinking there is a new feature that is adding a filter and I don’t where to change this. I just want 2 columns and not have to pick one or the other on the table.
Hello @palmergraf! You can use Outer join transformation to do this. You can learn more here:
And also a print screen on where you can find it:
Perfect! thank you very much. Did the trick
