[Question] could k6 browser function return a value to other functions?
Hi @inancgumus , sure.
Sorry to reply late, I am just back from vacation.
Here is what I want it to look like, for example, I have a set of data saved on the web and have check() for checking, there are multiple checks in there, so I want to have a label to use when I am done with the web test, and that label can be returned to the last main function because I want to save the total result inside a csv file.
It works for API testing, I would like to know if the k6 browser can do the same thing?
Yes, it should be possible using handleSummary
. Have you tried it?
