Question about Graffana panel on/off
Hello
Question about Graffan’s panel visualizations
I created a panel (stat template) with on/off options
I added a server to Querry.
Then everything works.
But I need to add 20 more servers.
And if even one of them is turned off, the status will change to off in the visualization.
If I add a new query, he creates a new square where the other server will be.
And if there will be 20+ servers doing the same thing, it won’t be what I need…
Is it possible . Create something like that?
