I am setting up Grafana in my docker container and I was confused about the configuration file format.
I have seen examples in both .ini
and .toml
syntax. I tried to figure this out with the documentation, but it doesn’t clearly state which formats are supported.
So is it ini
? Or is it toml
? Or a mix of both? Or either?
