QueryData method not triggered on Apply button click
    Grafana 9.2.5, Linux Ubuntu (WSL on Windows 10)
    I have written my backend datasource plugin (with streaming) using the Grafana Plugin SDK for Go.
    I have implemented the QueryData, RunStream, SubscribeStream and PublishStream methods for both streaming and non-streaming data in my backend datasource plugin.
  • What happened?
    The QueryData method in my backend datasource does not trigger when the Apply button is clicked in the Edit Panel view specifically for the timeseries visualization for the first time (only). It straight goes to the View mode; but editing the panel again and then clicking Apply button for the second time triggers the QueryData method (which is weird). For other visualizations like Chart Panel this problem does not occur. Only for time-series it seems to skip QueryData method for the first time (only).
    I was expecting that the QueryData method will get triggered everytime you click the Apply button in edit panel mode.
    The below is my QueryData method. No problems with it and it works fine. Just that it does not get triggered when I click the Apply button for the first time (only) for timeseries visualization.
func (d *RMFClient) QueryData(ctx context.Context, req *backend.QueryDataRequest) (*backend.QueryDataResponse, error) {
// create queryDataResponse struct
queryDataResponse := backend.NewQueryDataResponse()
if len(req.Queries) == 0 {
	return queryDataResponse, nil
// loop over queries and execute them individually.
for _, q := range req.Queries {
	dataResponse := d.query(ctx, req.PluginContext, q)
	if dataResponse != nil {
		queryDataResponse.Responses[q.RefID] = *dataResponse
    No errors.
    NA
An issue is logged with the Grafana team in the below link →
Timeseries Plugin has an issue: QueryData method in backend plugin not triggered on Apply button click (first time) · Issue #72837 · grafana/grafana (github.com)
