Query to identify slowest endpoints for an API (in terms of target_processing_time)
Grafana v10.0.3-cloud.4.aed62623 (d9eea1cb64)
The datasource is an ALB access logstream, where events are access requests for an aiohttp application that include strings of the form:
"GET https://<app name.org domain>:443/api/<endpoint> HTTP/2.0"
where endpoint is a string which can satisfy one of the following forms/schemes:
A
A/B
A/B/<param>
A/B/C
A/B/C/<param>
A/B/C/D
A/B/C/D/<param>
where A are alphanumeric strings, possibly including - and/or _, and <param> is a parameter or parameters, which are either integers or dates in the YYYY-MM-DD format.
I need to identify the endpoints uniquely up to the name parts (excluding the parameter parts), calculate the top 10 or 20 slowest endpoints, in descending order of target processing time.
    My current query is only trying to identify the endpoints up to the first part, A, and treating the rest as a remainder string (R). Here’s the full query.
avg by (A, R) (
    sum_over_time (
        {__aws_s3_lb="<ALB instance name>"}
        |= `/api`
        | pattern `<type> <timestamp> <elb> <client_ip> <target_ip> <request_processing_time> <target_processing_time> <response_processing_time> <elb_status_code> <target_status_code> <received_bytes> <sent_bytes> "<method> <_>/api/<endpoint> <_>"`
        | elb_status_code = 200
        | regexp `.*/api/(?P<A>[\w\-_]*)(?P<R>/.*)?`
        | target_processing_time > 0
        | unwrap target_processing_time [$__interval]
  • What happened?
    No data error
    A panel with data
    No data error
I think the issue is with the regex, but I could be wrong. Can someone please provide a pointer? Thanks.
