Im using grafana with influx ICMP tests. Idea is that i need to run multiple tests and if one of them fails - the window should be red. Definition of fail is that any of the test return ICMP MS more than ~30ms.
Is it possible ? I tried to do that with status panel, but seems it’s not what i need.
For example i have few simmilar metrics: SELECT mean(“rtt”) FROM “ping” WHERE “hostname” = ‘GoogletestfromJAYS7’ AND $timeFilter GROUP BY time(25s), “hostname” fill(null)
and if one of them returns more than X the whole window should indicate an alarm.
Can you help ? Thanks
