Public Dashboard Showing Drastically Different Values on Gauges
    Grafana installed via IOT Stack
    Create gauges that show the difference over a specific time for information to be shared on local network.
    I have created gauges that pull from the same source, measurements, and fields as the graphs next to them. Under query options I have set the relative time to the appropriate value (24h or 7d, 30d depending on the desired time range.) I set the calculation to difference. I have left the whole dashboard’s time range to 1 year. I have saved the dashboard and created a dashboard public link. Public dashboard is set to 1-year time range and range picker is not enabled.
  • What happened?
    When opening the public dashboard the graphs present as expected. The gauges all show drastically different data. It could be almost double the regular dashboard or even negative when it should be positive.
    Dashboard as seen in editor:
    Public Dashboard:
    I expected the gauges to display the same information on the public and regular dashboard.
I have found that enabling the time picker on the public dashboard does fix the display issue but I do not want that enabled.
Any suggestions?
