Public/build folder no longer exist for customization
Hello everyone,
I recently downloaded Grafana v10.2.2 by cloning the Grafana GitHub repository. I’m trying to customize the Grafana interface using the Docker method provided by Volkovlabs. This method worked well with ancien version of Grafana , but now I’m encountering an issue when attempting to remove the login session footer. It seems that the build folder (public/build) no longer exists.
Can anybody help me with this issue? Thanks in advance.
cc @mikhailvolkov
Hello I found a solution for my prob:
If you guys have a same prob, just update your yarn to the latest version then re-run the yarn install command, after that you can run your yarn build and your build folder will be successfully created in the public folder.
yarn cache clean -> yarn set version latest -> yarn install -> yarn build
