We have an issue that I cannot see on here already where our stats keep changing from the correct amount of storage free in GB to the same value in TB (See images). We are using the PRTG plugin, which I have used before without this issue.
What have you selected in the Unit field for your single stats?
If you are using a recent version of Grafana, you can use the query inspector to examine the raw data returned from PRTG. Does the raw data look correct? (Trying to figure out if this is a problem with the singlestat panel or with the PRTG data source).
