Hi!
Is there any proper way to parse duration in milliseconds, seconds and so on?
I’ve log output as duration in different formats - like 4.60ms, 5.45s, if I use these strings as metric source Promtail does not expose it to /metrics endpoint
So what should I do?
Is it needs to parse duration strings as numeric? If so, how it could be implemented?
Or is there any way to supply duration string (as ms or s format) to metrics directly?
Thanks a lot!
