Promtail Oauth config syntax
    Promtail 2.4.1
Enable Oauth for loki client endpoint
change the promtail config
  • What happened?
I receive various parsing errors on start-up:
Unable to parse config: /etc/promtail/promtail.yaml: yaml: line 10: did not find expected ‘-’ indicator
Unable to parse config: /etc/promtail/promtail.yaml: yaml: unmarshal errors:
line 12: field client_id not found in type client.raw
line 13: field client_secret not found in type client.raw
line 14: field token_url not found in type client.raw
line 14: cannot unmarshal !!seq into config.OAuth2
Oauth2 to be enabled
This is the config I expect to work:
clients:
  - url: LOKI_URL
  - oauth2:
    client_id: CLIENT_ID
    client_secret: CLIENT_SECRET
      - token_url: TOKEN_URL
But I have tried multiple other variartions (- in front of client_id/client_secret, no - in front of oauth2, no - in front of token_url, token_url not indented, brackets around client_id and client_secret.)
See Above
