I am using promtail to push messages from a plaintext logfile to loki. For extracting fields from the log messages, I am using the regex
stage.
However, this logfile contains different types of messages, and therefore I need to use different regex
expressions
for different types of messages.
It should be possible to achieve this using match
, but I am having trouble defining a working selector
I thought I could use something like this:
selector: '|~ ^log-message-type-1$'
However, this results in the following error: invalid selector syntax for match stage: parse error at line 0, col 1: syntax error: unexpected |~, expecting {
In all the examples in the docs, the selector
works with labels. These labels are usually already defined, because e.g. a journald scraper sets various labels for each log message. A static_config
(plaintext) scraper does not.
I think I could probably extract the whole message to a label like this:
- regex:
expression: ^(?P<msg>.*?)$
- labels:
msg:
(... match stages....)
- labeldrop:
- msg
And then use a selector like this:
selector: '{msg=~"^log-message-type-1$"}'
But this seems really complicated for such a simple task.
Is there a better solution for this?
