While in the promtail.yml/config file where you can add Job_name and the like. For syslog, and specifically ‘listen_address’, how can I have the port be a UDP instead of the default TCP? Or at least I’m thinking you could do that? While reading the logs and I just did the dumb thing of 0.0.0.0:514/udp (obviously wrong), but when I did that the logs stated “tcp: address tcp/514/udp: unknown port” From that I’m assuming that if you put an address and port in the listen_address, it just assumes you’re doing the TCP port-type.
How do you make it listen to the UDP? Is this some kind of syntax that I just don’t know yet?
Thanks.
