I have created alerts using node-exporter, prometheus and grafana.
Query used for CPU :-
100 * (1 - avg(rate(node_cpu_seconds_total{mode=“idle”, instance=“custom:port” , job=“nodeexporter”}[1m])))
when the alerts triggered it sends an alerts but the actual problem is when i compare alerts with GCP alerts its shows different values. like in GCP its 45% then in Grafana its 80%.
Note:- GCP alerting the correct values checked and verified.
How to solve this problem Grafana alerts showing wrong values how to get the exact values.
Steps:
- Changed scrape_interval to 5s.
- changed CPU query
- checked prometheus collecting the same data as it shows in Grafana.
Prometheus.yml file:-
global:
scrape_interval: 15s
evaluation_interval: 15s
alerting:
alertmanagers:
- static_configs:
- targets:
rule_files:
scrape_configs:
- job_name: "prometheus"static_configs:
- targets: [“customip:port”]
