Prometheus Java Agent Connection reset Errors
I am having a strange issue while Prometheus trying to scrape data from my Tomcat hosts.
I am getting “Get “http://HOSTNAME:30018/metrics”: read TCP :54232-> :30018: read: connection reset by peer” randomly. I have 10 API hosts and at any time only 3 or 4 API hosts will respond to the GET query. The remaining will throw a connection reset error.
Doing a tcpdump on API host shows Tomcat is sending the RESET packet:
Output when I do curl http://localhost:30018/metrics
11:26:13.445191 IP xxxxx.30018 > xxxxxx.36506: Flags [R.], seq 1, ack 89, win 512, options [nop,nop,TS val 1244760697 ecr 1244700645], length 0
We are running Prometheus 2.45.0 version and prometheus agent - jmx_prometheus_javaagent-0.18.0.jar
Any advise on what could be causing this issue?
Thank you
If any one ends up with this issue, solution is to check Tomcat config files and setup params such as maxAge and switching to the new pool for each wars
factory=“org.apache.tomcat.jdbc.pool.DataSourceFactory”
maxAge=“14400000”
