Prometheus configuring volumes and storage on windows 10
  • What happened?
  • What Grafana version: grafana 8.4 and windows 10
  • **What trying to achieve?
    Want to configure yaml file on windows. All yaml files found on Internet are like /var/log or /etc/config, both are linux folders. And want to monitor prometheus
    Trying to use default yaml file, as given everywhere on Internet using /var/log and /etc/config.
  • What happened?
    prometheus is running (ports 9090/9090). But cannot see any data in grafana or prometheus
    wanted to be able to execute queries on prometheus, self monitoring of prometheus.
    services:
    prometheus:
    image: prom/prometheus:v2.34.0
    volumes:
    - ./prometheus/:/etc/prometheus/
    command:
    - “–config.file=/etc/prometheus/prometheus.yml”
    - “–storage.tsdb.path=/prometheus”
    ports:
    - 9090:9090
    networks:
    - grafana
  • Did you receive any errors in the Grafana UI or in related logs?
    Cannot find any logs. Where are they?
    I followed “Grafana fundamentals | Grafana Labs
Are you trying to run prometheus in windows or in docker?
