iamp3
1
Hi all,
When im trying to connect my prometheus server with nginx basic auth to grafana, i got 401 error code on OPTIONS request.
By the way, i can easily login with this credential on main prometheus page. How i can fix it or where i can find some information about this topic?
iamp3
2
That was CORS problem. Solved by next configuration -->
location / {
if ($request_method = 'OPTIONS') {
add_header 'Access-Control-Allow-Origin' '*';
add_header 'Access-Control-Allow-Methods' 'GET, POST, OPTIONS';
add_header 'Access-Control-Allow-Headers' 'DNT,Authorization,Accept,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Range';
add_header 'Access-Control-Max-Age' 1728000;
add_header 'Content-Type' 'text/plain; charset=utf-8';
add_header 'Content-Length' 0;
return 204;
if ($request_method = 'POST') {
add_header 'Access-Control-Allow-Headers' 'DNT,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Range';
add_header 'Access-Control-Expose-Headers' 'Content-Length,Content-Range';
if ($request_method = 'GET') {
auth_basic "Prometheus";
auth_basic_user_file /etc/nginx/conf.d/.htpasswd;
proxy_pass http://prometheus-server;
