Hello
I am using “process exporter” from which I get all metrics needed.
I am having hard time for creating alert which will trigger when residential memory reaches 80% of virutal memory.
namedprocess_namegroup_memory_bytes{groupname=“map[:myApp.jar]”, memtype=“resident”, group=“process”, job=“$envirovment”} -
namedprocess_namegroup_memory_bytes{groupname=“map[:myApp.jar]”, memtype=“virtual”, group=“process”, job=“$envirovment”}
Problem is that I can not use metric “namedprocess_namegroup_memory_bytes” two times. How can I achive this?
Thank you.
