Procedure to reference multiple Dashboards using a single GrafanaDashboard CustomResource
    Grafana Operator 4.10.1 and Grafana version 9.x on Kubernetes Platform
    Trying to understand procedure on how to reference multiple configmaps/json files to load multiple dashboards at one go using GrafanaDashboard CustomResource
    Using GrafanaDashboard Kind CustomResource and not successful
  • What happened?
    No documentation avaialable to configure multiple configmap references
    Spec section that can allow multiple configmap references to load many Grafana dashboard jsons at one go
    apiVersion: integreatly.org/v1alpha1
    kind: GrafanaDashboard
    metadata:
    labels:
    app: grafana
    spec:
    configMapRef:
    key: sample-dashboard.json
    Nops…
    All Grafana community blogs
Any help is much appreciated…
