I’m having issues authenticating into my on-premise Grafana 10.0.3-1 instance running on CentOS Linux release 7.9.2009 related to the case insensitive login change, see Guide to using the new Grafana CLI user identity conflict tool in Grafana 9.3 | Grafana Labs
The problem is that the conflict resolution tool doesn’t work for me, probably related because it’s the admin user for which I configured my personal email years ago.
sudo grafana cli admin user-manager conflicts list
Showing conflicts
conflict: user.name@domain.com
+ id: 1, email: user.name@domain.com, login: admin, last_seen_at: 2020-12-16T18:52:21Z, auth_module: , conflict_email: true, conflict_login:
- id: 35, email: User.Name@domain.com, login: username, last_seen_at: 2023-08-03T12:23:10Z, auth_module: ldap, conflict_email: true, conflict_login:
When I try to validate the conflicts file, it says validation complete:
sudo grafana cli admin user-manager conflicts validate-file /tmp/conflicting_user_2154898624.diff
File validation complete.
File can be used with the `ingest-file` command.
But when I try to ingest, it throws an error:
sudo grafana cli admin user-manager conflicts ingest-file /tmp/conflicting_user_2154898624.diff
Changes that will take place
Keep the following user.
The following user(s) will be deleted.
We encourage users to create a db backup before running this command.
Proceed with operation? [y|n]: y
Error: ✗ not able to merge with &{%!e(string=could not find intoUser: Found a conflict in user login information. 2 users already exist with either the same login or email: [admin (email:user.name@domain.com, id:1), username (email:User.Name@domain.com, id:35)].) %!e(*user.ErrCaseInsensitiveLoginConflict=&{[{1 0 user.name@domain.com UserLastName UserFirstName admin cef596b61d55df46e9bfed317f00f739b3ffd4fa2c912e2fa86b671b27e7bf8733f2d67866780da29bc3265339e22fee2fb3 DS1YPPWHIz VFc9kCXnZF false 0 false true false 2 {0 63578429585 0x68c0e60} {0 63743741561 0x68c0e60} {0 63743741541 0x68c0e60}} {35 0 User.Name@domain.com UserFirstName UserLastName username i29n0HGztw g8i59SdVTY false 1 false true false 1 {0 63630114051 0x68c0e60} {0 63743797516 0x68c0e60} {0 63826662190 0x68c0e60}}]})}
I tried finding a way to update the email address of admin, but failed.
Setting “admin_email = anotheremail@domain.com” in /etc/grafana/grafana.ini and restarting Grafana does not work. Disabling LDAP authentication does not enable me to login with admin.
Please advice how to resolve this problem.
Willem
