Problem with variable not updated correctly
    Grafana 8.5.25 on docker container.
    I have some time series influx data coming from telegraf agent to monitor nginx stats.
    The data looks like this:
    nginx,ecs.metric.category=nginx,ecs.swarm=cloud-net,host={host} accepts=877i,active=45i,handled=877i,reading=0i,requests=3370i,waiting=43i,writing=2i 1696484670000000000
I created some dashboards and i want to also have an “all” option to show sum of these stats for all containers hosting nginx.
    I created a query variable for the dashboard.
    Type:query
    Refresh on time range
    Include “all” option.
    And since i dont want to show values for old containers i have the following query:
    “SHOW TAG VALUES FROM “nginx” WITH KEY=host WHERE time > now() -10m”
  • What happened?
    After deployment it works fine, but if nginx container moves to another host i can still see the old values of host in the variable (of course with no data)
    The variable would show only “hosts” that had metrics in the last 10 minutes.
    No
I think the problem is on how the “time” is calculated and what now() returns. Is there any hint how these two are calculated in Grafana?
