Problem with prometheus + ceph cluster
Hello. I got ceph cluster on which I enable prometheus plugin. It works, I can access it and watch metrics like http://192.168.0.105:9283/metrics. Then, I install grafana(Grafana v4.6.3 (commit: 7a06a47)) on ubuntu 16.04. I add data source:
and I got error with no code… Okey, then I try to add dashboard. I add it, and it loks like this:
And when I access this board, I got this in syslog:
Syslog
Try and change the access mode to proxy.
Marcus
you must install https://prometheus.io (port 9090) server with Ceph exporter (port 9283).
Ceph does not provide Prometheus, it is just provide exporter for Prometheus.
