Problem Time Range "Now"
Hello together,
sorry i am new. Tried a lot since two day. Search doesnt help, because i am not sure what to search… and everything found didnt help.
My Data in “table view” is 2h ahead.
I adjusted everything around, but if i watch the graphs by “relative time” e.g. " -5 min till now" it shows me the data “my time” -5 min → 2h back from data.
Here my data in mariaDB:
Here my data in grafana:
I could live with that, but the problem is, grafana is doing something with "Time + Value “Bezugsleistung”
It doesnt show me the write value in the graph. I think its the problem of the timeshift…
How is it possible to store right Time in “table view” = grafana?
Thankyou
Welcome @martinhassinger
Sounds like your date column is not UTC
Use a mariadb function to convert it to UTC
Thank you.
I read this before, but not sure how to manage.
Here is my Timezone (thats the point):
grafik
I made a new field (8) for “Zeit UTC”, but cant choose something like Datetime UTC…
Can u tell me how to fill new field with time UTC?
Thanks a lot
That ia beyond grafana. I would consult mariadb documentation
Instead of changing or adding table column qouls be easier to use a function like this
convert_tz
Example
convert_tz(createddate,'America/New_York','UTC') as time,
CONVERT_TZ - MariaDB Knowledge Base.
