HI,
Nice tool! and we want to check it out
we try with the following dummy test and I’ve two main questions
export let options = {
insecureSkipTLSVerify: true,
tags: {
url: 'https://httpbin.org/get',
scenarios: {
constant_req_rate: {
executor: 'constant-arrival-rate',
rate: 1000,
timeUnit: '1s',
duration: '120s',
preAllocatedVUs: 1000,
maxVUs: 1000,
tags: {', url: "https://httpbin.org/get" },
thresholds: {
'http_req_duration': ['p(95)<1500'], // 99% of requests must complete below 1.5s
'health is ok': ['p(99)<1500'], // 99% of requests must complete below 1.5s
export default () => {
group("test 1", () =>{
let healthRes = http.get(`${BASE_URL}`, {
tags: {name: 'PostsItemURL'},
check(healthRes, {
'status is ok!': (r) => r.status === 200,
My questions are:
- we want to add the url as output, how can I do it ? in the docs I saw that
req.url
params but when I addconsole.log(url)
I see it multi times in the output , is it possible to add the url where the status is ok place or other place ? - if we need to run 1000 request per second but constant my config is valid ?
- there is lots of docs which is great, is there any best practices to run constant check on high load?
Regards,
Ryan
