What Grafana version and what operating system are you using? I have a client machine with data stored in InfluxDB v2. The same machine has Grafana v12.0.1. I have dashboards in the local grafana that connect to the Influx DB. It works well
What are you trying to achieve? I would like to be able to use the Grafana AI tools to look at the data for possible problems
How are you trying to achieve it? Im referring to How to use AI to analyze and visualize CAN data with Grafana Assistant | Grafana Labs but am completely new to this architecture
What happened? Nothing yet. Looking for a Primer on how to do this
Grafana Assistant is Grafana Cloud feature:
So you need Grafana Cloud instance first. You can’t use it with your on-prem Grafana.
You may try to use third party plugins with your on-prem Grafana, e.g. Graft:
Im happy to use it in a grafana cloud instance. Id like to know how I can move data from my on-prem into a form which cloud can readily use. Currently the data resides in influxdb v2 on-prem. The on-prem grafana is used for visualizations of the time series data (weather-related).
Hi @zubenubi
It can be done by installing / configuring the Private Data Source Connect for Grafana on the server where you have InfluxDB on-prem being run and then Grafana Cloud can connect to that private server.
