Using powSeries on a time series renders an odd ‘half graph’ as in the screenshot.
The screenshot shows a wifi link quality signal (green line) and a yellow line that should have been the wifi signal raised to the second power (using powSeries).
(If I use powSeries on two constant lines the rendering is correct.)
Am I doing something wrong?
