I am struggling to determine how to query a Postgres datasource from a page in an app that I am developing. I basically need to do tag mapping on the page and I want to query Postgres for a list of all available tags. I am referencing this ticket but do not know where to go to learn what functions are available for doing the actual querying.
In my digging I discovered this and I believe that I could use it to accomplish my needs. The only piece I’m not certain about is the data
object and what are the expected formats, types, etc.
this.backendSrv
.datasourceRequest({
url: '/api/tsdb/query',
method: 'POST',
data: {
to: options.range.to.valueOf().toString(),
queries: queries,
.then(this.responseParser.processQueryResult);
Am I on the right track?
I realize now that my most recent comment will not work. That datasource query will return an object intended for painting to the graph. I suspect that if I were to send a query asking for just metadata it would break the query.
Well, I was able to figure it out. In case anyone ever comes along wondering how to do the same here is how I did it:
- Load your datasource as explained in the post that I linked to. Mine looked like this for Postgres:
loadDatasource(id) {
return this.backendSrv.get('api/datasources/' + id)
.then(ds => {
this.datasource = ds.jsonData.ds;
return this.datasourceSrv.get(ds.name);
}).then(psqlDS => {
this.psqlDS = psqlDS;
return psqlDS;
- Then you can use a function available in the Postgres Datasource called “metricFindQuery” to send any query you want to your Postgres Datasource. The digging I had to do took me to public/app/plugins/datasource/postgres/datasource.ts for learning more about the Postgres Datasource. And here is my code snippet:
this.loadDatasource().then(() => {
this.psqlDS.metricFindQuery(
"SELECT column_name,
table_name
FROM information.schema.columns
WHERE table_name
IN (SELECT tableName
FROM pg_catalog.pg_tables
WHERE schemaname='public')")
.then(resp => {
this.test = resp
I hope this helps someone else down the road!!
