I have next table in Postgres database, I need to show an amount and duration of active task on grafana graph.
Can you please help. What script should be to create this graph?
Should be something like this:
Thanks.
Thanks.
You can use this plugin
and next query:
SELECT
id AS metric,
1 as value,
start as time
FROM table
WHERE $timeFilter(start)
union
SELECT
id AS metric,
0 as value,
stop as time
FROM table
WHERE stop is not null and $timeFilter(stop)
