Popular time Plugin
Hi Team,
Is there any way to see the “The most popular time” in server other than heat map plugins?
I meant something like Google map - Most popular time.
Thanks in advance.
Best,
Siddharth
Do you mean like the histogram option in the Graph panel?
Yup sort of. I need date to be on x axis. That isn’t coming.
Another option: Carpet plot plugin for Grafana | Grafana Labs
But what does your data look like? It sounded like to me that you want to group into buckets for “time of day”. So you would not have time on the x-axis, you would have your “time of day” buckets on the x-axis e.g. Bucket1: 9 a.m. - 10 a.m. Bucket2 10 a.m. to 11 a.m. Which is the same as the histogram in the screenshot above or in the carpet plot panel.
Thanks! Appreciate your help!
