Hi there!
Please help me to solve the problem with the values mapping.
I’ve created a variable $services with type Query and get data from database that looks like this:
SELECT [ServiceName] AS __text, [ServiceId] AS __value
FROM [Services]
The result is something like:
__text | __value
backend | a1s1d1f1
frontend | q2w2e2r2
proxy | z3x3c3v3
And now when I select needed service I get corresponding value by query like this:
some_prometeus_metric{service="$services"}
It’s OK. But how can I point to exact value in query without selecting it in dropdown menu?
For example:
some_prometeus_metric{service="$services.backend"}
some_prometeus_metric{service="$services:backend"}
I have more than 250 services and don’t want to use their ids which are too long. Instead I want to use service name which are short and useful. Is there any possibility to do this?
Maybe I can use another approach setting each service name as a separate variable.
So I will get a set of variables:
$backend = a1s1d1f1
$frontend = q2w2e2r2
$proxy = z3x3c3v3
But how can I do it by query and not manually?
