Kubernetes 9.0.5 on kubernetes 1.28 via helm -
install grafana to eventually update alert rules -
upgrade the alert rules in 9.0.5 to eventually be able to eventually migrate to grafana 11.0 -
What happened?
Error: unable to build kubernetes objects from release manifest: [resource mapping not found for name: “grafana-shd” namespace: “” from “”: no matches for kind “PodSecurityPolicy” in version “extensions/v1beta1”
ensure CRDs are installed first, resource mapping not found for name: “grafana-shd-test” namespace: “” from “”: no matches for kind “PodSecurityPolicy” in version “policy/v1beta1”
ensure CRDs are installed first] -
Install grafana 9.0.5 on kubernetes 1.28 -
helm pull grafana/grafana --untar --version 6.33.0. ### values file -
no this is prior to UI being up -
Did you follow any online instructions? If so, what is the URL? n/a
