Plugin PolyStat doesnt change colors
I’m trying to adopt plugin called Polystat which displays aggregated metrics in one panel.
It looks very trivial and straightforward, but somehow the threshold colors change doesnt work:
means, Once i define thresholds with relevant colors, it didnt change.
From picture, you can see that it should change to Red color.
Can you show the query inspect output so I can try to reproduce this?
It should be changing colors from the config shown above.
Hi, I am having same problem, I need CUSTOM color TEXT when mouse is over hexagon, text is the same color as hexagon, so its ureadable when over other hexagons.
that’s a good feature request - will add it :slight_smile:
