# Plugin installation problem
**URL:** <https://community.grafana.com/t/plugin-installation-problem/29130>\
**Category:** Installation\
**Created:** [April 23, 2020, 10:34am UTC](https://community.grafana.com/t/plugin-installation-problem/29130 "2020-04-23T10:34:33Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![mata](https://avatars.discourse-cdn.com/v4/letter/m/3e96dc/32.png) [@mata](https://community.grafana.com/u/mata)\
**Post date:** [April 23, 2020, 10:34am UTC](https://community.grafana.com/t/plugin-installation-problem/29130/1 "2020-04-23T10:34:33Z")
</div>
I install plugin with
sudo grafana-cli plugins install grafana-worldmap-panel
restart service with
sudo /opt/bitnami/ctlscript.sh restart grafana
all is ok
plugin is installed correctly but I can’t see it in the dashbord
can someone help me?
Tanks
**Author:** ![ahmedfarhan](https://avatars.discourse-cdn.com/v4/letter/a/fbc32d/32.png) [@ahmedfarhan](https://community.grafana.com/u/ahmedfarhan)\
**Post date:** [April 28, 2020, 6:50am UTC](https://community.grafana.com/t/plugin-installation-problem/29130/2 "2020-04-28T06:50:09Z")
</div>
> [@mata](#):
You are installing grafana as root, grafan might be running under different user name, did you check the plugindir permission? Check the plugins dir permission
**Author:** ![ngszehung](https://avatars.discourse-cdn.com/v4/letter/n/848f3c/32.png) [@ngszehung](https://community.grafana.com/u/ngszehung)\
**Post date:** [May 28, 2020, 12:41pm UTC](https://community.grafana.com/t/plugin-installation-problem/29130/3 "2020-05-28T12:41:07Z")
</div>
I have the same problem.
I can see worldmap in plugins inside the grafana interface but cannot see the dashboard
I use : sudo docker exec -it c449b31d /bin/bash
and found that plugins in /var/lib/grafana/plugins directory, with user grafana/grafana
seems no problem in directory permission
any help is appreciated
**Post date:** [May 29, 2020, 1:19am UTC](https://community.grafana.com/t/plugin-installation-problem/29130/4 "2020-05-29T01:19:31Z")
</div>
I got that resolved. thanks
