Hi
Imagine that your plugin creates some files on an abstract backend.
You click “add new file” and then you want to click “Save dashboard”. It would be great
- Get notification about saving process initiation and do saving which I need in my plugin
- Stop saving process if plugin failed to save something.
So I can sync plugin.json with actual state of all system. Can I achieve this anyhow?
