Ping ip address
Hi, may I know how to get the result for pinging a multiple ip addresses and visualize it in Grafana? Is it possible to store the data in mysql? Or is there any solution/the way for directly pinging from Grafana? Appreciate your assistance. Thank you.
You need to have some script or tool which does this and puts the results into
a data store from which Grafana can display those results.
Yes, if that is the data store of your choice. There are many to choose from.
Or is there any solution / the way for directly pinging from Grafana?
No.
Grafana does not perform checks such as this. Grafana takes values from a
data store and displays them in “wallboard-style” dashboards.
What that data is and where it comes from is independent of Grafana.
Regards,
Antony.
Hi Antony, thank you so much for your replies. I get a clearer picture now.
I planned to write a php script for pinging ip addresses and store the results into mysql db. The results should be a real time and execute row per second to be stored in the db. Is it possible for me to do that & is it possible for mysql db to store such a multiple data?
Regards,
Farah.
