HI
how to change the format data (%.f)
all in bytes (35360592264), how displayed data in Gb (35Gb)?
In singlestat and gauge panel you can change the unit to the base. In this case bytes and it will format for you.
plugin PictureIt doesn’t have this menu!
Oh, I’m sorry. Didn’t realize Picturelt was a plugin. I see that you created an issue on their github repo, I hope it will get resolved soon.
