How do you show cputime of a process as percent cpu in Grafana?
My backend of InfluxDB 1.3.1
Data is coming from collectd 5.7.1
not sure, depends on what metrics you have. do you know what fields / metrics you collectd collect? do you have cpu count, idle, system etc?
GM Torkel,
I have the following:
show series where instance = ‘ads’ and type = ‘ps_cputime’
processes_syst,host=localhost,instance=ads,type=ps_cputime
processes_user,host=localhost,instance=ads,type=ps_cputime
ok, so you have only ps_cputime metric? what does the collectd docs say this value represents?
Per the code, the value is in microseconds
ok, you need other values as well to calculate percent idle / used
