Pei chart panel with date picker filter
    I’m trying to show a pei chart with values i’m getting using promql query
    I wrote a simple query with sum function that returns sum of errors
    Than I’m trying to narrow the results using the grafana date picker
  • What happened?
    I’m getting wrong result.
    say on 13:00 I got 100 errors
    On 13:20 i’m getting another 20.
    and on 13:30 I’m choosing to get the results on the last 15 minutes I’m getting 120
    I’m expecting to get the error i got only on the last 15 minutes (20 in the exmaple)
    The query:
    sum(init_vehicle_success_failure{status = ‘failure’}) by (service)
    No
