Just noticed this error in my logs…
Feb 11 13:55:35 openplotter signalk-server[495]: at IncomingMessage.<anonymous> (/home/pi/.signalk/node_modules/@influxdata/influxdb-client/dist/index.js:5:5671)
Feb 11 13:55:35 openplotter signalk-server[495]: at IncomingMessage.emit (node:events:539:35)
Feb 11 13:55:35 openplotter signalk-server[495]: at endReadableNT (node:internal/streams/readable:1345:12)
Feb 11 13:55:35 openplotter signalk-server[495]: at processTicksAndRejections (node:internal/process/task_queues:83:21) {
Feb 11 13:55:35 openplotter signalk-server[495]: statusCode: 422,
Feb 11 13:55:35 openplotter signalk-server[495]: statusMessage: 'Unprocessable Entity',
Feb 11 13:55:35 openplotter signalk-server[495]: body: '{"code":"unprocessable entity","message":"failure writing points to database: partial write: field type conflict: input field \\"value\\" on measurement \\"navigation.courseOverGroundTrue\\" is type float, already exists as type string dropped=4"}',
Feb 11 13:55:35 openplotter signalk-server[495]: contentType: 'application/json; charset=utf-8',
Feb 11 13:55:35 openplotter signalk-server[495]: json: {
Feb 11 13:55:35 openplotter signalk-server[495]: code: 'unprocessable entity',
Feb 11 13:55:35 openplotter signalk-server[495]: message: 'failure writing points to database: partial write: field type conflict: input field "value" on measurement "navigation.courseOverGroundTrue" is type float, already exists as type string dropped=4'
Feb 11 13:55:35 openplotter signalk-server[495]: },
Feb 11 13:55:35 openplotter signalk-server[495]: _retryAfter: 0
Feb 11 13:55:35 openplotter signalk-server[495]: }```
* What Grafana version and what operating system are you using? 9.3.2 on raspberry pi
* **What** are you trying to achieve?
* **How** are you trying to achieve it?
* What happened?
error above
* What did you **expect** to happen?
* Can you copy/paste the configuration(s) that you are having problems with?
* Did you receive any errors in the Grafana UI or in related logs? If so, please tell us **exactly** what they were.
* Did you follow any online instructions? If so, what is the URL?
