Good Evening,
I am looking to create a dashboard that polls an XML file at a URL to get the status of relays and display them on a dashboard.
Example URL: http://ip_address/state.xml
Example Data:
<datavalues>
<input1state>0</input1state>
<input2state>0</input2state>
<hightime1>0.000</hightime1>
<hightime2>0.000</hightime2>
<count1>0</count1>
<count2>0</count2>
<relay1state>0</relay1state>
<relay2state>0</relay2state>
<relay3state>0</relay3state>
<relay4state>1</relay4state>
<relay5state>1</relay5state>
<relay6state>1</relay6state>
<relay7state>1</relay7state>
<relay8state>1</relay8state>
<relay9state>0</relay9state>
<relay10state>0</relay10state>
<units>F</units>
<sensor1temp>65.8</sensor1temp>
<sensor2temp>x.x</sensor2temp>
<sensor3temp>x.x</sensor3temp>
<sensor4temp>x.x</sensor4temp>
<sensor5temp>x.x</sensor5temp>
<sensor6temp>x.x</sensor6temp>
<sensor7temp>x.x</sensor7temp>
<sensor8temp>x.x</sensor8temp>
<sensor9temp>x.x</sensor9temp>
<sensor10temp>x.x</sensor10temp>
<extvar0>0.00</extvar0>
<extvar1>0.00</extvar1>
<extvar2>0.00</extvar2>
<extvar3>0.00</extvar3>
<extvar4>0.00</extvar4>
<serialNumber>00:0C:C8:05:33:21</serialNumber>
<time>1673731309</time>
</datavalues>
<relay*State> will be 0 for off or 1 for on. Want to place specific ones on a dashboard.
Any help would be appreciated. Thanks in Advance.
