I would like to parse a csv and plot its content in Grafana.
I have a csv like the following:
date,key0,key1
20220610t133612,5260,3.05
20220610t133712,5260,78.4
Converted it in a list of json:
{"date": "20220610t133612", "key0": "5260", "key1": "3.05"}
{"date": "20220610t133712", "key0": "5260", "key1": "78.4"}
Use the following config.yaml
server:
http_listen_port: 0
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
client:
url: https://<redacted>@logs-prod-eu-west-0.grafana.net/loki/api/v1/push
scrape_configs:
- job_name: system
pipeline_stages:
- json:
expressions:
output: data
stream: stream
timestamp: date
key0:
key1:
- timestamp:
source: timestamp
format: "20060102t150405"
static_configs:
- targets:
- localhost
labels:
job: data
__path__: /var/log/*.log
Send data using promtail:
podman run \
--name promtail \
--volume "$PWD/config.yaml:/etc/promtail/config.yaml" \
--volume "$PWD:/var/log" \
grafana/promtail:master \
-config.file=/etc/promtail/config.yaml \
-log.level=debug
If I try to query the data for a new Panel:
{job="data"} | json | line_format "{{.ping}}"
I can see the data only in a table format.
It does not allow me to plot the timeseries.
Any ideas?
Thanks
